estofex alerta de tempestade - possibilidade de tornados
Mensagempor cookie » quarta fev 16, 2011 10:07 am
Companheiros,
o estofex lançou um alerta de tempestade com a possibilidade de tornados na zona centro e sul de portugal.
estejam alerta.
Storm Forecast
Storm Forecast
Valid: Wed 16 Feb 2011 06:00 to Thu 17 Feb 2011 06:00 UTC
Issued: Wed 16 Feb 2011 08:04
Forecaster: PUCIK
A level 1 was issued for Southwestern Iberia mainly for severe wind gusts and tornadoes.
SYNOPSIS
In the strong northwesterly flow over Southwestern Europe, a low pressure system will move over Iberia towards the Southern Mediterranean. Several vorticity maxima are simulated along the periphery of the low, propagating in the strong jet-stream, reaching up to 50 m/s at 500 hPa level. It is this region, Southern, Western Mediterranean and coastal areas of Iberia, that should experience conditions favorable for deep, moist convection. The rest of Europe should strive in the stable environment with a ridge over Central Europe and a deep low over Russia. The low owes its origin to the very cold airmass being advected over the region. This airmass involves temperatures under -20°C at 850 hPa and its boundary with a modified polar airmass over the rest of Europe is actually the most significant one during this forecast period.
DISCUSSION
... Southwestern Iberia ...
Models simulate rather marginal instability built-up, but with favorable forcing, as revealed by vorticity advection fields at 500 and 300 hPa levels and sufficient moisture, scattered thunderstorms might initiate. With strong northwesterly flow especially over the southern part of the region, moderate to strong wind shear is predicted. Most of the wind shear will be concentrated to the lowest 1 km, especially over the inland areas, where bulk values well over 10 m/s are predicted. It is quite probable that a linearly organised system of thunderstorms develops ahead of one of the vorticity maxima and travels southeastwards. Marginally severe wind gusts and/or weak tornadoes might accompany the passage, as well as isolated small hail. The overall threat seems to warrant a low-end Level 1.
... Western Mediterranean ...
It will be this region, that should experience the highest coverage of thunderstorms with sufficient forcing and instability fields overlapping each other. Most of the thunderstorm activity will likely be observed during the night hours and will gradually move towards the east, in accordance with the movement of the mid-level features.
Mensagempor seco » quarta fev 16, 2011 12:48 pm
Boas (espro)
Foi declarado alerta vermelho em toda à costa devido à possibilidade de ondas com 10 metros
seco
Mensagempor paulobraz » quarta fev 16, 2011 1:54 pm
10 metros muito bom para o meu Bodyboard.
Mas a Polícia Marítima não me deixou ir para o mar.
:x :x
paulobraz
Mensagempor cookie » quarta fev 16, 2011 2:16 pm
acabo de ouvir nas notícias que de manhã ocorreu um pequeno tornado na zona de vendas novas.
companheiro paulobraz, as ondas até podem ser grandes mas o mar deve estar completamente desfeito, o que para os desportos de mar não é grande coisa certo? já para não falar na sua vida :wink:
Mensagempor las2855 » quarta fev 16, 2011 11:45 pm
Penso que foi granizo de ontem à noite e o vento forte o responsável pela quebra e arranque do arejador (cogumelo) de tecto da casa de banho da minha AC deixando o céu à vista!
Felizmente choveu no duche. Nada mais apropriado. :wink:
Cordialmente,
las2855
las2855
Mensagempor cookie » quinta fev 17, 2011 8:21 am
las2855 Escreveu:Penso que foi granizo de ontem à noite e o vento forte o responsável pela quebra e arranque do arejador (cogumelo) de tecto da casa de banho da minha AC deixando o céu à vista!
glups... espero que o arranjo seja... suave.
Mensagempor ZecaSantos » quinta fev 17, 2011 1:05 pm
Boas tardes
las2855, teve sorte porque o "cogumelo" e a sua aplicação é rápida e barata, se fosse uma claraboia era muito mais dispendioso.
Saudações Autocaravanistas
Zeca Santos
ZecaSantos
Mensagempor las2855 » quinta fev 17, 2011 11:07 pm
Tenho a minha AC estacionada no exterior.
Fiquei chocado com o estado degradado e enfraquecido da peça de plástico ao fim de 4 anos ao sol e à chuva.
Nada com ter uma AC protegida do sol e chuva...
Cordialmente,
las2855
las2855
Mensagempor paulobraz » sexta fev 18, 2011 12:44 pm
cookie Escreveu:acabo de ouvir nas notícias que de manhã ocorreu um pequeno tornado na zona de vendas novas.
Correcto amigo! Mas ondas destas são raras apanhar.
paulobraz
